It is currently Wed Sep 17, 2025 1:23 pm
PostPosted: Sat Mar 12, 2022 7:15 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I'd like to add some variety to my current project by making it a 'slothead'. The neck I am using was joined with a 1/2" peghead, and my veneer/rosewood cap adds an eighth of an inch to the headstock thickness, a total of 5/8". But I don't know the thickness that a slotted headstock needs to be.
I'd appreciate some guidance.
Thanks!
Peter Havriluk
PostPosted: Sat Mar 12, 2022 7:38 pm
No, That's not even close. You need 13/16" Min. for most tuners.
PostPosted: Sat Mar 12, 2022 7:41 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
It needs to be as thick as your slotted head tuners require, and they do vary. The Gotoh tuner has a base plate that is 16 mm wide - that’s about the same as your 5/8 thickness, but gives no allowance for centering or the protrusion of the shaft end past the head plate. Off the top of my head I’m saying about 19 mm. I have a couple in progress, so I can measure those tomorrow.
PostPosted: Sat Mar 12, 2022 7:50 pm
First name: Josh
The Waverly slothead tuners are the narrowest I’ve found and let you go a little thinner (~2mm) than the Grover. I’m building a slothead w/ Waverly at the moment. Next time I’m in the shop I’ll measure them for you, if you like.
PostPosted: Sat Mar 12, 2022 8:02 pm
3/4 inch
PostPosted: Sat Mar 12, 2022 8:03 pm
The Rubners I’m using on my latest have a side plate width of 0.72”. So 13/16” would be a good peghead thickness for those.
PostPosted: Sat Mar 12, 2022 8:19 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Thanks, everybody!
I'll hold that thought for another project.
Peter Havriluk
PostPosted: Sat Mar 12, 2022 10:36 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Add a backstrap to make up the difference on the one you're working on.
These users thanked the author CarlD for the post: phavriluk (Sat Mar 12, 2022 11:28 pm)
PostPosted: Sat Mar 12, 2022 11:37 pm
I did that, and if you want do do an 8 string you might squeak by with 11/16ths using mandolin tuners (always have your tuners on hand before making the final decision).
